跳转到主内容
GM Key Fob Plastic Housing Replacement
你所需要的
  1. GM Key Fob  Plastic Housing Replacement, Key Fob Plastic Housing: 步骤 1 中的图像 1,1
    • Pry apart the key ring to remove it from the old housing.
  2. GM Key Fob  Plastic Housing Replacement: 步骤 2 中的图像 1,3 GM Key Fob  Plastic Housing Replacement: 步骤 2 中的图像 2,3 GM Key Fob  Plastic Housing Replacement: 步骤 2 中的图像 3,3
    • Once you have removed the key ring, use it to open the housing by wedging it into the groove, as pictured.
  3. GM Key Fob  Plastic Housing Replacement: 步骤 3 中的图像 1,2 GM Key Fob  Plastic Housing Replacement: 步骤 3 中的图像 2,2
    • Remove the electrical board and rubber key pad from the old housing.
  4. GM Key Fob  Plastic Housing Replacement: 步骤 4 中的图像 1,2 GM Key Fob  Plastic Housing Replacement: 步骤 4 中的图像 2,2
    • Remove the electrical board from the rubber key pad.
  5. GM Key Fob  Plastic Housing Replacement: 步骤 5 中的图像 1,2 GM Key Fob  Plastic Housing Replacement: 步骤 5 中的图像 2,2
    • If necessary, remove the battery from the electrical board and replace it.
  6. GM Key Fob  Plastic Housing Replacement: 步骤 6 中的图像 1,1
    • After Opening the new Key Fob package, select the correct housing as more than one model is included.
结论
To reassemble your device, simply follow these disassembly instructions in reverse order.
另外一个人完成了本指南。
Megan Hayden
于10/06/16注册
136 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 72
总计 2,178
