跳转到主内容
GE TrueTemp Oven Light Bulb Replacement
你所需要的
  1. GE TrueTemp Oven Light Bulb Replacement, Light Bulb: 步骤 1 中的图像 1,1
    • Unplug the power cord from the wall outlet for safety purposes.
  2. GE TrueTemp Oven Light Bulb Replacement: 步骤 2 中的图像 1,1
    • Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
  3. GE TrueTemp Oven Light Bulb Replacement: 步骤 3 中的图像 1,1
    • Locate the metal strap holding the glass cover over the bulb.
  4. GE TrueTemp Oven Light Bulb Replacement: 步骤 4 中的图像 1,1
    • Slide the strap to the side to free the glass casing.
  5. GE TrueTemp Oven Light Bulb Replacement: 步骤 5 中的图像 1,1
    • View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
    • Check to make sure there is no debris around the bulb and that the light bulb is ready to be removed.
  6. GE TrueTemp Oven Light Bulb Replacement: 步骤 6 中的图像 1,1
    • Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
  7. GE TrueTemp Oven Light Bulb Replacement: 步骤 7 中的图像 1,2 GE TrueTemp Oven Light Bulb Replacement: 步骤 7 中的图像 2,2
    • Screw in new light bulb in the clock wise direction.
  8. GE TrueTemp Oven Light Bulb Replacement: 步骤 8 中的图像 1,1
    • Replace the glass cover over the bulb, but be sure to hold on to it tightly.
  9. GE TrueTemp Oven Light Bulb Replacement: 步骤 9 中的图像 1,1
    • Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
  10. GE TrueTemp Oven Light Bulb Replacement: 步骤 10 中的图像 1,1
    • Plug the oven power cord back into power source.
  11. GE TrueTemp Oven Light Bulb Replacement: 步骤 11 中的图像 1,1
    • Press the button for oven light to come on.
  12. GE TrueTemp Oven Light Bulb Replacement: 步骤 12 中的图像 1,1
    • View light to ensure the replacement was successful.
终点
Samantha Connell
于01/21/18注册
214 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 132
总计 15,990
