跳转到主内容
GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement
你所需要的
  1. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: 步骤 1 中的图像 1,3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: 步骤 1 中的图像 2,3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: 步骤 1 中的图像 3,3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: 步骤 2 中的图像 1,2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: 步骤 2 中的图像 2,2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: 步骤 3 中的图像 1,2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: 步骤 3 中的图像 2,2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, LCD Cover: 步骤 4 中的图像 1,1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: 步骤 5 中的图像 1,2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: 步骤 5 中的图像 2,2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
结论
2等其他人完成本指南。
Dominick Giguere
于10/28/14注册
848 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 365
