1. Release the 3 clips that attach the front fan guard to the rear fan guard. Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  2. Pull the front fan guard off.
    • Pull the front fan guard off.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Remove the spinner from the center of the fan blade. Remove the spinner from the center of the fan blade.
    • Remove the spinner from the center of the fan blade.
  5. The fan blades should now be easy to lift up.
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
结论
5等其他人完成本指南。
Alan Su
于2012年10月03日注册
537 信誉积分
创作了6篇指南
团队
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G28
4 名成员
创作了10篇指南
Where do you buy the fan blades?
charlie - 回复
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 12
总计 2,256
