跳转到主内容
GD Midea FT30-3D Fan Base Disassembly
你所需要的
  1. GD Midea FT30-3D Fan Base Disassembly, Bottom Base: 步骤 1 中的图像 1,1
    • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
  2. GD Midea FT30-3D Fan Base Disassembly: 步骤 2 中的图像 1,2 GD Midea FT30-3D Fan Base Disassembly: 步骤 2 中的图像 2,2
    • Locate the gray base support release tabs found on either side pictured in the first image.
    • There are release tabs on each side of the base.
    • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
  3. GD Midea FT30-3D Fan Base Disassembly: 步骤 3 中的图像 1,1
    • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
    • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
  4. GD Midea FT30-3D Fan Base Disassembly: 步骤 4 中的图像 1,1
    • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
  5. GD Midea FT30-3D Fan Base Disassembly: 步骤 5 中的图像 1,1
    • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
    • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
  6. GD Midea FT30-3D Fan Base Disassembly: 步骤 6 中的图像 1,1
    • Once all five screws have been removed the base cover should fall right off with out any effort.
    • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
结论
4等其他人完成本指南。
Alan Su
于10/03/12注册
810 声望
创作了6篇指南
团队
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G28
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 18
总计 1,526
