跳转到主内容
GBC Creative Laminator Gear Replacement
你所需要的
  1. GBC Creative Laminator Gear Replacement, Gear: 步骤 1 中的图像 1,2 GBC Creative Laminator Gear Replacement, Gear: 步骤 1 中的图像 2,2
    • Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device.
  2. GBC Creative Laminator Gear Replacement: 步骤 2 中的图像 1,1
    • Open the top of the device, and the inside of the Laminator will be exposed as shown.
  3. GBC Creative Laminator Gear Replacement: 步骤 3 中的图像 1,3 GBC Creative Laminator Gear Replacement: 步骤 3 中的图像 2,3 GBC Creative Laminator Gear Replacement: 步骤 3 中的图像 3,3
    • Using the Phillips #2 screwdriver, remove the two 9 mm long screws on the side of the main component that fix the motor in place.
    • Pull the motor off of the main internal component to reveal the gear.
  4. GBC Creative Laminator Gear Replacement: 步骤 4 中的图像 1,1
    • Pull the gear off of the motor.
结论
4等其他人完成本指南。
Yujia Tang
于07/11/18注册
384 声望
创作了2篇指南
团队
IUPUI, Team S1-G1, Wilson Summer 2018 IUPUI, Team S1-G1, Wilson Summer 2018 的会员
IUPUI-WILSON-SU18S1G1
5 名成员
创作了4篇指南
一条评论
Can you tell me where I might find a replacement gear for my GBC H200? I would like to find a brass gear but mine melted and need to find a replacement but no info for the gear. I think it is 17 teeth but not sure about the rest.
Jim Pruitt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 24
过去 30 天: 69
总计 3,400
