跳转到主内容
GATEWAY NE56R09u Hard Drive Replacement
你所需要的
  1. GATEWAY NE56R09u Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
  4. GATEWAY NE56R09u Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Using the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the hard drive. These 2 screws are what is also keeping the hard drive in place.
  5. GATEWAY NE56R09u Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Push firmly down on the center of the hard drive and with a swiping to the left motion release the clip from the drive.
  6. GATEWAY NE56R09u Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Once the drive has been released, simple lift up the hard drive to remove it.
结论
To reassemble your device, please follow these instructions in reverse order.
joshua depina
于03/25/19注册
401 声望
创作了3篇指南
团队
UMass Dartmouth, Team S6-G1, Peak Spring 2019 UMass Dartmouth, Team S6-G1, Peak Spring 2019 的会员
UMASSD-PEAK-S19S6G1
2 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 201
