跳转到主内容
GATEWAY NE56R09u Battery Replacement
你所需要的
  1. GATEWAY NE56R09u Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u Battery Replacement: 步骤 2 中的图像 1,1
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u Battery Replacement: 步骤 3 中的图像 1,1
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
结论
To insert the new battery, follow these instructions in reverse order.
joshua depina
于03/25/19注册
401 声望
创作了3篇指南
团队
UMass Dartmouth, Team S6-G1, Peak Spring 2019 UMass Dartmouth, Team S6-G1, Peak Spring 2019 的会员
UMASSD-PEAK-S19S6G1
2 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 195
