跳转到主内容
加入维修社区 - 创建账户
GATEWAY ML6720 Keyboard Replacement
你所需要的
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Keyboard Replacement: 步骤 5 中的图像 1,1
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
  5. GATEWAY ML6720 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,3 GATEWAY ML6720 Keyboard Replacement, Keyboard: 步骤 6 中的图像 2,3 GATEWAY ML6720 Keyboard Replacement, Keyboard: 步骤 6 中的图像 3,3
    • Be careful of losing the screws because of how small they are
    • Remove the six 2.0mm Phillips screws and panels from the back of the RAM, motherboard, and laptop fan.
  6. GATEWAY ML6720 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Have your laptop remained on the backside
    • Remove the twelve identical 2.0mm Phillips Screws located around the back of the laptop using the Phillips #0 Screwdriver.
    • Remove the entire back panel of the laptop
  7. GATEWAY ML6720 Keyboard Replacement: 步骤 8 中的图像 1,2 GATEWAY ML6720 Keyboard Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a pair of tweezers or the tip of your screw driver, dig into the laptop cover and apply force to pop it out.
    • Do this on the left and right side of the cover.
  8. GATEWAY ML6720 Keyboard Replacement: 步骤 9 中的图像 1,2 GATEWAY ML6720 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Pull up the keyboard with your finger.
结论
Nathan Da Silva
于10/19/16注册
416 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G3
2 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 688
