跳转到主内容
GARDENA Smart Gateway Repair
你所需要的
  1. GARDENA Smart Gateway Repair, Open device: 步骤 1 中的图像 1,2 GARDENA Smart Gateway Repair, Open device: 步骤 1 中的图像 2,2
    • Remove the rubber feet. Below are four Torx T9 screws.
  2. GARDENA Smart Gateway Repair, Fuse: 步骤 2 中的图像 1,1
    • Identify if the fuse is blown. Take a multimeter and measure the resistance. There should be no measurable resistance.
    • If the fuse is defective it should be replaced with a new one. Component listed under parts.
  3. GARDENA Smart Gateway Repair, TVS Diode: 步骤 3 中的图像 1,1
    • Second component likely to fail is the TVS Diode (Transient-voltage-suppression diode). It is used to protect the sensitive circuit from overvoltage.
    • Measure the resistance on the two terminals. Resistance should be infinite.
    • If component is broken the circuit is shorted. Therefore the component can be removed in order to repair the device. Afterwards the circuit is not protected against overvoltage anymore!
  4. GARDENA Smart Gateway Repair, Test the device: 步骤 4 中的图像 1,1
    • Power LED should light up green
结论
Computerix
于05/24/23注册
770 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 1,259
