跳转到主内容
G'z One Boulder New Antenna Replacement
你所需要的
  1. G'z One Boulder New Antenna Replacement, New Battery: 步骤 1 中的图像 1,2 G'z One Boulder New Antenna Replacement, New Battery: 步骤 1 中的图像 2,2
    • Turn locking device on back side of phone marked by the rectangle counter clockwise.
  2. G'z One Boulder New Antenna Replacement: 步骤 2 中的图像 1,1
    • Remove battery by grabbing the sides and pulling upward.
    • If battery was malfunctioning due to age or corrosion, there may be battery acid residue on the battery and the back of the phone. Wear gloves in order to prevent skin irritation.
  3. G'z One Boulder New Antenna Replacement, New Antenna: 步骤 3 中的图像 1,3 G'z One Boulder New Antenna Replacement, New Antenna: 步骤 3 中的图像 2,3 G'z One Boulder New Antenna Replacement, New Antenna: 步骤 3 中的图像 3,3
    • Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws.
    • Once all screws are removed the case will easily lift off.
  4. G'z One Boulder New Antenna Replacement: 步骤 4 中的图像 1,2 G'z One Boulder New Antenna Replacement: 步骤 4 中的图像 2,2
    • With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
  5. G'z One Boulder New Antenna Replacement: 步骤 5 中的图像 1,2 G'z One Boulder New Antenna Replacement: 步骤 5 中的图像 2,2
    • With screw removed, gently pull the antenna outward. It should slide out easily.
结论
troy
于03/11/13注册
1 声望
创作了2篇指南
团队
Clemson, Team 13-3, Benson Spring 2013 Clemson, Team 13-3, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G3
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 467
