当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
Make note that two of the screws closest to the hinge are longer than the other two.
Remove the two side screws.
When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
Use a plastic opening tool to remove the screen cover from the rest of the lid.
Your phone should look like the picture to the left.
If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
取消:我没有完成这个指南。
与3其他贡献者
于03/11/13注册
4 声望
创作了2篇指南
徽章: 5
+ 2更多徽章
CLEM-BENSON-S13S13G3
3 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 10
总计 502
