你所需要的
Reinstall the selector plate by sliding the front end in first.
After the selector plate is back in place, reinstall the spring by carefully popping both ends back on to the nubs on the selector plate and cutoff lever. A dental pick is helpful for this.
Put the wire harness back in place by sliding the lower portion down into the slot in the gearbox, then pushing the top end back down. There is a round hole in the harness that corresponds to a small peg in the gearbox. Don't forget to hook the trigger plunger spring back onto its post.
Reinstall the small screw that holds the wire harness in place.
Make sure the trigger spring is attached to the trigger as shown.
Place the gears back in the gearbox starting with the spur gear. Check to make sure that there are no loose shims around.
Before installing the bevel gear, place the anti-reversal latch in and turn it clockwise so that spring tension will push it up against the bevel gear. Refer to the third picture and be sure you are installing it exactly as shown.
Press on the air nozzle to ensure that it slides back and springs forward when released.
Reinstall the main spring and spring guide. Placing a tool such as a thin screwdriver into the rear of the spring guide can assist in pushing the spring in and holding the guide down.
Place the right half of the gearbox back on top. It is best to start from the rear, at the spring guide, then pull the gearbox half forward over the cylinder head.
Make sure all of the gears, anti-reversal latch, and trigger line up in their respective holes.
To reassemble the hop-up unit and barrel, first slide the hop-up bucking onto the barrel, making sure to slide the line in the bucking into the groove in the barrel.
Then slide the barrel and bucking into the hop-up unit with the groove in the barrel facing down, and install the green clip.
Finally, slide the brass ring around the barrel and into the front of the hop-up unit.
Slide the upper receiver back onto the lower receiver, arranging the wires as shown. You will need to lift the charging handle over the nub on the top of the gearbox, just as you did when disassembling the gun.
After the wires have been slid through the upper receiver, push the front takedown pin back in.
4等其他人完成本指南。
4指南评论
We're do I get the screws to ajust the motor in the grip I have one of the is and the person that I got it from cut the wire to the battery and I have enough to splice them together but it's not gonna be wright is their a # or a company that replaces or fixes them.
And I have a H&K mp5 with the same problem battery must go in the handle and the wires went even short enough to even splice on that one
Hi!
I have thoroughly visited this web site it has good information on carbine rifles which is helpful to everyone in the community but i have also visited a website yesterday that is on sniper long range rifles which is also a good and comprehensive site on long range or short range rifles. so I also recommend u people to visit that site also. Highly recommended:
Hello, good day, I want to get information from you about something. I. I disassemble and attach Airsoft Guns very easily. I work in an airsoft gun store. I have about 40 50 Airsoft guns in my hand, but some guns do not shoot one by one. May I know which part is having trouble with this or what should I do? to throw one by one .It fires bullets automatically when I press the trigger. Even though the gun is Semi.What should I do? I would be very happy if you let me know. Have a nice day. Good luck.
