跳转到主内容
  1. Turn locking device on back side of phone marked by the rectangle counter clockwise. Turn locking device on back side of phone marked by the rectangle counter clockwise.
    • Turn locking device on back side of phone marked by the rectangle counter clockwise.
  2. Remove battery by grabbing the sides and pulling upward.
    • Remove battery by grabbing the sides and pulling upward.
    • If battery was malfunctioning due to age or corrosion, there may be battery acid residue on the battery and the back of the phone. Wear gloves in order to prevent skin irritation.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws. Once all screws are removed the case will easily lift off. Once all screws are removed the case will easily lift off.
    • Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws.
    • Once all screws are removed the case will easily lift off.
  5. With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place. With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
    • With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
  6. With screw removed, gently pull the antenna outward. It should slide out easily. With screw removed, gently pull the antenna outward. It should slide out easily.
    • With screw removed, gently pull the antenna outward. It should slide out easily.
结论
troy
于2013年03月11日注册
1 信誉积分
创作了2篇指南
团队
Clemson, Team 13-3, Benson Spring 2013 Clemson, Team 13-3, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G3
3 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 363
