跳转到主内容
配件
没有特定配件。
  1. There are 4 black screws that need to be removed on the top of the lid.  A 1.5mm flathead screwdriver will work on the star shaped screw heads.
    • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
    • Make note that two of the screws closest to the hinge are longer than the other two.
  2. Remove the two side screws. When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
    • Remove the two side screws.
    • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Use a plastic opening tool to remove the screen cover from the rest of the lid. Use a plastic opening tool to remove the screen cover from the rest of the lid.
    • Use a plastic opening tool to remove the screen cover from the rest of the lid.
  5. Your phone should look like the picture to the left. If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
    • Your phone should look like the picture to the left.
    • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
  6. Remove one screw located on the left side of the phone with the pictured orientation in mind. This will release the logic board from the back case. Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
    • Remove one screw located on the left side of the phone with the pictured orientation in mind.
    • This will release the logic board from the back case.
    • Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
  7. Pull the logic board out with a pry stick gently from bottom to top at the current orientation. The ribbon cable will be connected underneath the logic board.  A small amount of force is required to disconnect them. Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
    • Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
    • The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
    • Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
结论
Raymond Caulder
于2013年03月11日注册
22 信誉积分
创作了3篇指南
团队
Clemson, Team 13-3, Benson Spring 2013 Clemson, Team 13-3, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G3
3 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 8
总计 593
