跳转到主内容
Fusion5 5.5 Gen II Midframe Replacement
你所需要的
  1. Fusion5 5.5 Gen II Midframe Replacement, Back Cover: 步骤 1 中的图像 1,2 Fusion5 5.5 Gen II Midframe Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Midframe Replacement, Midframe: 步骤 2 中的图像 1,2 Fusion5 5.5 Gen II Midframe Replacement, Midframe: 步骤 2 中的图像 2,2
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Midframe Replacement: 步骤 3 中的图像 1,2 Fusion5 5.5 Gen II Midframe Replacement: 步骤 3 中的图像 2,2
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
结论
另外一个人完成了本指南。
1指南评论
Hi Hwajin,
Thanks for your guides to the Fusion5. Do you happen to have a full User Manual. The quick start guide is useless.
Regards,
Richard
richardsailor1936@gmail.com - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 408
