跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Furby Outer Shell Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Furby Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 1,3 Furby Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 2,3 Furby Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 3,3
    • Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
  2. Furby Outer Shell Replacement: 步骤 2 中的图像 1,3 Furby Outer Shell Replacement: 步骤 2 中的图像 2,3 Furby Outer Shell Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 driver to unscrew the eight 10mm screws.
    • Remove the base ring after unscrewing all the screws.
    • Be careful when lifting the base ring from the Furby. There are sharp edges that hold the base ring in place.
  3. Furby Outer Shell Replacement: 步骤 3 中的图像 1,2 Furby Outer Shell Replacement: 步骤 3 中的图像 2,2
    • Unhook the white ribbon from the tab on the base.
  4. Furby Outer Shell Replacement: 步骤 4 中的图像 1,3 Furby Outer Shell Replacement: 步骤 4 中的图像 2,3 Furby Outer Shell Replacement: 步骤 4 中的图像 3,3
    • Roll the Furby's fur downward.
    • Disconnect the now exposed red wire.
  5. Furby Outer Shell Replacement: 步骤 5 中的图像 1,3 Furby Outer Shell Replacement: 步骤 5 中的图像 2,3 Furby Outer Shell Replacement: 步骤 5 中的图像 3,3
    • Locate the two middle clips first.
    • Locate the two remaining clips on Furby's sides, they are opposite each other.
    • Orient the Furby upside down with the tail facing away from you.
  6. Furby Outer Shell Replacement: 步骤 6 中的图像 1,3 Furby Outer Shell Replacement: 步骤 6 中的图像 2,3 Furby Outer Shell Replacement: 步骤 6 中的图像 3,3
    • Insert a metal prying tool directly into the clip opening.
    • Press upward into the clip. At the same time, use your other hand to pull away the plastic seam from the Furby's body.
    • Repeat the previous step to remove the remaining three clips.
  7. Furby Outer Shell Replacement: 步骤 7 中的图像 1,3 Furby Outer Shell Replacement: 步骤 7 中的图像 2,3 Furby Outer Shell Replacement: 步骤 7 中的图像 3,3
    • Locate the two 10mm screws and remove them with the Phillips #0 head screwdriver.
    • Lift up on the fur covering until the face of the Furby is exposed.
  8. Furby Outer Shell Replacement: 步骤 8 中的图像 1,3 Furby Outer Shell Replacement: 步骤 8 中的图像 2,3 Furby Outer Shell Replacement: 步骤 8 中的图像 3,3
    • Orient the Furby on its side to where the beak is facing left and locate the edge of the aluminum tape.
    • Lift tape gently and peel back until the tape is nearly removed.
    • Do not pull on the yellow wire located on the opposite end of the tape.
  9. Furby Outer Shell Replacement: 步骤 9 中的图像 1,2 Furby Outer Shell Replacement: 步骤 9 中的图像 2,2
    • Locate the four 10mm screws. Two on either side of body, and two on top of back plate, around the tape.
    • Remove the 10mm screws with the Phillips#0 screwdriver.
  10. Furby Outer Shell Replacement: 步骤 10 中的图像 1,1
    • Peel the tape gently, grabbing it from the bottom edge and folding the tape upward.
    • Peel the tape up until it is nearly detached from the black case.
  11. Furby Outer Shell Replacement: 步骤 11 中的图像 1,2 Furby Outer Shell Replacement: 步骤 11 中的图像 2,2
    • Orient the Furby face down, with the base facing away from you.
    • Locate the clips below the ears.
    • Repeat the technique used in Step 6. Create leverage using a metal prying tool to press upward into the clip, while also pulling back on the clip itself.
  12. Furby Outer Shell Replacement: 步骤 12 中的图像 1,2 Furby Outer Shell Replacement: 步骤 12 中的图像 2,2
    • Remove the loose, plastic back panel by pulling the panel away from Furby's body.
终点
另外一个人完成了本指南。
团队
Cal Poly, Team 15-5, Livingston Fall 2016 Cal Poly, Team 15-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G5
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 90
