跳转到主内容
Furby "Feet" Cleaning Guide
你所需要的
  1. Furby "Feet" Cleaning Guide, Furby "Feet" Cleaning Guide: 步骤 1 中的图像 1,3 Furby "Feet" Cleaning Guide, Furby "Feet" Cleaning Guide: 步骤 1 中的图像 2,3 Furby "Feet" Cleaning Guide, Furby "Feet" Cleaning Guide: 步骤 1 中的图像 3,3
    • Flip Furby upside down so his feet are pointed towards you.
    • Unscrew the right and left screws on the base.
  2. Furby "Feet" Cleaning Guide: 步骤 2 中的图像 1,3 Furby "Feet" Cleaning Guide: 步骤 2 中的图像 2,3 Furby "Feet" Cleaning Guide: 步骤 2 中的图像 3,3
    • Remove the base from your Furby.
    • Flip over the base so the screws are on the right and left.
    • Unscrew the 2 right and 2 left inside screws.
  3. Furby "Feet" Cleaning Guide: 步骤 3 中的图像 1,3 Furby "Feet" Cleaning Guide: 步骤 3 中的图像 2,3 Furby "Feet" Cleaning Guide: 步骤 3 中的图像 3,3
    • Lift the housing for the foot components.
    • Rotate the base 90 degrees.
    • Locate all four of the foot activation levers. Remove them one by one from the base.
  4. Furby "Feet" Cleaning Guide: 步骤 4 中的图像 1,2 Furby "Feet" Cleaning Guide: 步骤 4 中的图像 2,2
    • Locate the feet pieces and remove them.
  5. Furby "Feet" Cleaning Guide: 步骤 5 中的图像 1,3 Furby "Feet" Cleaning Guide: 步骤 5 中的图像 2,3 Furby "Feet" Cleaning Guide: 步骤 5 中的图像 3,3
    • Locate and gently lift out the four small springs using tweezers.
    • Now that you have all parts are removed, they can be cleaned and reassembled into Furby's "feet".
结论
团队
Cal Poly, Team 15-5, Livingston Fall 2016 Cal Poly, Team 15-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G5
4 名成员
创作了9篇指南
一条评论
I greet my furby boom 2012 he falls asleep and when I wake him up he starts to cry and then he falls asleep. This started after a week without using.What I can do,Thanks for your help.Juan
jrrabrito - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 1,409
