跳转到主内容
Furbo Dog Camera USB Power Jack Replacement
你所需要的
  1. Furbo Dog Camera USB Power Jack Replacement, Back Cover: 步骤 1 中的图像 1,2 Furbo Dog Camera USB Power Jack Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera USB Power Jack Replacement: 步骤 2 中的图像 1,3 Furbo Dog Camera USB Power Jack Replacement: 步骤 2 中的图像 2,3 Furbo Dog Camera USB Power Jack Replacement: 步骤 2 中的图像 3,3
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera USB Power Jack Replacement: 步骤 3 中的图像 1,3 Furbo Dog Camera USB Power Jack Replacement: 步骤 3 中的图像 2,3 Furbo Dog Camera USB Power Jack Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    购买
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera USB Power Jack Replacement: 步骤 4 中的图像 1,3 Furbo Dog Camera USB Power Jack Replacement: 步骤 4 中的图像 2,3 Furbo Dog Camera USB Power Jack Replacement: 步骤 4 中的图像 3,3
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
  5. Furbo Dog Camera USB Power Jack Replacement: 步骤 5 中的图像 1,2 Furbo Dog Camera USB Power Jack Replacement: 步骤 5 中的图像 2,2
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
  6. Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: 步骤 6 中的图像 1,2 Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: 步骤 6 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws from the USB power jack.
  7. Furbo Dog Camera USB Power Jack Replacement: 步骤 7 中的图像 1,2 Furbo Dog Camera USB Power Jack Replacement: 步骤 7 中的图像 2,2
    • Once you have removed the screws, gently pull the bundled cable connector free from the motherboard.
  8. Furbo Dog Camera USB Power Jack Replacement: 步骤 8 中的图像 1,3 Furbo Dog Camera USB Power Jack Replacement: 步骤 8 中的图像 2,3 Furbo Dog Camera USB Power Jack Replacement: 步骤 8 中的图像 3,3
    • The USB power jack PCB can now be removed from your Furbo and replaced.
终点
另外一个人完成了本指南。
一条评论
Where can you find a replacement
Brandon Alves - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 37
总计 1,224
