简介
This guide will show you how to remove the barking sensor assembly from your Furbo Dog Camera. Removing and replacing your barking sensor assembly may fix any issues that were not able to be fixed by troubleshooting.
你所需要的
在这个步骤中使用的工具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
即将完成!
结论
