跳转到主内容
Furbo Dog Camera Barking Sensor Assembly Replacement
你所需要的
  1. Furbo Dog Camera Barking Sensor Assembly Replacement, Back Cover: 步骤 1 中的图像 1,2 Furbo Dog Camera Barking Sensor Assembly Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 2 中的图像 1,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 2 中的图像 2,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 2 中的图像 3,3
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 3 中的图像 1,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 3 中的图像 2,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    购买
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 4 中的图像 1,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 4 中的图像 2,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 4 中的图像 3,3
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
  5. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 5 中的图像 1,2 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 5 中的图像 2,2
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
  6. Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: 步骤 6 中的图像 1,3 Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: 步骤 6 中的图像 2,3 Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: 步骤 6 中的图像 3,3
    • Carefully remove the copper foiling that surrounds the camera hardware.
  7. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 7 中的图像 1,2 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the 2.5 mm screws at the top of the camera hardware.
  8. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 8 中的图像 1,2 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 8 中的图像 2,2
    • Gently pry the metal backing off of the camera hardware.
  9. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 9 中的图像 1,2 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 9 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the 0.4 mm screws that attach the camera to the Furbo case.
  10. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 10 中的图像 1,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 10 中的图像 2,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 10 中的图像 3,3
    • Gently pry the camera off and detach it from the Furbo.
  11. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 11 中的图像 1,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 11 中的图像 2,3 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 11 中的图像 3,3
    • Detach the wire attaching the camera hardware from the Furbo.
  12. Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 12 中的图像 1,2 Furbo Dog Camera Barking Sensor Assembly Replacement: 步骤 12 中的图像 2,2
    • Once removed, you may replace your camera.
  13. Furbo Dog Camera Barking Sensor Assembly Replacement, Barking Sensor Assembly: 步骤 13 中的图像 1,1
    • Remove the barking sensor and replace it with a new part.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 151
