Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Turn to the bottom of the camera.
Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
Start from the battery compartment and remove the back cover.
Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
Remove the connecting ribbon from the body of the camera using a pair of tweezers.
Remove 2 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
Caution: Do not tug on the LCD screen because this could tear the ribbon connecting the LCD screen to the body of the camera.
Loosen the black ribbon clamp using an iPod opening tool
Release the LCD screen by removing the ribbon from the body of the camera.
Unscrew 2 3.35mm phillips head screw from the face of the function key motherboard using a #00 phillips head screwdriver.
Caution: Do not tug on the motherboard because this will tear the ribbon connecting the motherboard to the body of the camera.
Release the black ribbon clamp attached to the back of the motherboard using an iPod opening tool to lift the clamp.
Remove the ribbon connecting the function key motherboard from the body of the camera using tweezers.
The function key motherboard has the SD card reader attached to the back. The motherboard and SD card combination should be replaced.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
