当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Use the 10 mm nuts and bolts to attach the two plates together. First, hand thread each bolt/nut pair, then use two 10 mm wrenches secure them.
DO NOT install a nut and bolt in the THIRD hole from the center (pointed end of the section). This is where the Pipe Ring Bracket is attached later on.
这个步骤还没有翻译 帮忙翻译一下
Slide the cross bearer into the two holes in the support ring making sure the top of the cross sticks through the center of the solar panel dish.
Insert a 14mm bolt into the metal bracket on the support ring through the adjustable arm and secure with a nut.
Tighten with your hands.
2等其他人完成本指南。
3条评论
Thank you very much ,mine came without the instructions so this has been so helpful
crafty mav - 回复
Hi everyone, I want to ask about the material used over the dish. whether it's concave mirror or some sheet. kindly someone clear my confusion. Thank you
