简介
The solar cooker assembly should be performed in an large open area with nothing that obstructs the sunlight. We recommend at least two people for the quickest and easiest assembly.
你所需要的
An inventory for all parabolic solar cooker parts follows below.
6 Reflective Dish Sections
1 Expansion Pipe
1 Tripod Center Plate
1 T-Bar
3 Tripod Base Legs
1 Cooker Flat
1 Pipe Ring
Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
Lay two triangular sections side-by-side with pointed edges and bases adjacent to each other.
Use the 10 mm nuts and bolts to attach the two plates together. First, hand thread each bolt/nut pair, then use two 10 mm wrenches secure them.
DO NOT install a nut and bolt in the THIRD hole from the center (pointed end of the section). This is where the Pipe Ring Bracket is attached later on.
Place the assembled solar panel dish face down with the metal brackets on the top and facing up.
Set the pipe ring in the metal brackets circling the center of the dish.
To disassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
5指南评论
Thank you very much ,mine came without the instructions so this has been so helpful
crafty mav - 回复 分享
Hi everyone, I want to ask about the material used over the dish. whether it's concave mirror or some sheet. kindly someone clear my confusion. Thank you
Hello, I brought the unit last year and I am looking or locate who and where can I purchase the hardware package, the unit that came missing 1/3 of the bolts, clips, and nuts,
I like to purchase a complete hardware package for my Full Solar cooker unit.
my email: pn91006@yahoo.com
Cell: 626-215-4038
Can I order the following part that was missing from the order that came in Aug 2025?
Please let me know, I can pay for these parts from you stock or spare parts.
36 x 10mm Nut/Bolt Pairs
6 Pipe Ring Brackets
12 x 14mm Nut/Bolt Pairs
2 Cooker Assembly Adjustment Star Knobs
Paul
my email is pn91006@yahoo.com
626-215-4038
Paul Ng
