跳转到主内容
Fujtsu Lifebook Model A6110 Disk Drive Replacement
你所需要的
  1. Fujtsu Lifebook Model A6110 Disk Drive Replacement, Battery: 步骤 1 中的图像 1,2 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 步骤 2 中的图像 1,1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
  3. Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 1,3 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 2,3 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 3,3
    • The disk drive will be located on the side of the computer, on the top-left corner
    • Using a Phillips #1 screwdriver, remove the two 6 mm screws which are located above the disk drive. Remove the screws by turning your screwdriver counter-clockwise.
  4. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 步骤 4 中的图像 1,2 Fujtsu Lifebook Model A6110 Disk Drive Replacement: 步骤 4 中的图像 2,2
    • Insert the metal spudger in the gap between the disk drive and the laptop's body itself, as seen in the picture.
    • Push the spudger down, so that it is behind the drive.
    • Gently pull the disk drive out from the laptop until it unlatches.
  5. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 步骤 5 中的图像 1,1
    • Once the disk-drive has been unlatched from its slot, pull it gently from the laptop case.
结论
Cody Moniz
于10/19/16注册
416 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 UMass Dartmouth, Team 3-2, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 426
