简介
If your laptop fails in reading whatever disc you have, then the problem may lie on either your disc or your disk drive. This guide will show you the steps to replace your disk drive.
你所需要的
Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
The disk drive will be located on the side of the computer, on the top-left corner
Using a Phillips #1 screwdriver, remove the two 6 mm screws which are located above the disk drive. Remove the screws by turning your screwdriver counter-clockwise.
