跳转到主内容
Fujtsu Lifebook Model A6110 Battery Replacement
  1. Fujtsu Lifebook Model A6110 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Fujtsu Lifebook Model A6110 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Battery Replacement: 步骤 2 中的图像 1,1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
结论
Alvin Thamrin
于10/25/16注册
132 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 UMass Dartmouth, Team 3-2, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G2
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 580
