跳转到主内容
Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement
你所需要的
  1. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn the laptop over so that the bottom of the laptop faces you.
  2. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 2 中的图像 1,2 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Locate the hard drive cover and remove the screw.
  3. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 3 中的图像 1,2 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Now you can use your finger to pull the cover off.
  4. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 4 中的图像 1,3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 4 中的图像 2,3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Pull on the pull tab to release the hard drive.
    • Now you can take the hard drive out of the laptop.
  5. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 5 中的图像 1,3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 5 中的图像 2,3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • There is a screw on each corner of the hard drive bracket. To take the hard drive out of its bracket you need to remove the 4 screws.
    • Do not take the screws out of the hard drive itself, only from the bracket.
    • With the screws removed the drive slides out of the bracket.
    • Now you can replace the hard drive with a new one.
结论
5等其他人完成本指南。
storm
于07/07/12注册
552 声望
创作了2篇指南
2条评论
Please I need a password protection my computer is locked I need a code to unlock my computer pls Esprimo mobile V5515 please help me
sadik G Ibrahim - 回复
Is it a Windows password or a BIOS password?
storm -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 45
总计 6,013
