跳转到主内容
Fujitsu Siemens Amilo Pro Keyboard Replacement
你所需要的
  1. Fujitsu Siemens Amilo Pro Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Fujitsu Siemens Amilo Pro Keyboard Replacement: 步骤 2 中的图像 1,1
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. Fujitsu Siemens Amilo Pro Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the one screw holding in the keyboard.
  4. Fujitsu Siemens Amilo Pro Keyboard Replacement: 步骤 4 中的图像 1,1
    • Pull the keyboard up towards you.
  5. Fujitsu Siemens Amilo Pro Keyboard Replacement: 步骤 5 中的图像 1,1
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
结论
另外一个人完成了本指南。
一条评论
try to focus the image while taking the picture so people can understand better were to touch
storm builder - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 15,560
