跳转到主内容
Fujitsu Lifebook Stylistic Q584 USB port Replacement
你所需要的
  1. Fujitsu Lifebook Stylistic Q584 USB port Replacement, Back Case: 步骤 1 中的图像 1,1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 USB port Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 USB port Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 USB port Replacement, Inner Back Shield: 步骤 4 中的图像 1,1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 USB port Replacement: 步骤 5 中的图像 1,1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 USB port Replacement: 步骤 6 中的图像 1,1
  7. Fujitsu Lifebook Stylistic Q584 USB port Replacement: 步骤 7 中的图像 1,1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 USB port Replacement, USB port: 步骤 8 中的图像 1,1
    • Remove 2mm screw with a PH1 screwdriver from USB board
  9. Fujitsu Lifebook Stylistic Q584 USB port Replacement: 步骤 9 中的图像 1,1
    • Disconnect USB periphery ribbon from motherboard
  10. Fujitsu Lifebook Stylistic Q584 USB port Replacement: 步骤 10 中的图像 1,1
    • Pull USB board up to remove.
结论
Spencer Bacon
于09/21/17注册
410 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 505
