跳转到主内容
加入维修社区 - 创建账户
Fujitsu Lifebook Stylistic Q584 Speakers Replacement
你所需要的
  1. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Back Case: 步骤 1 中的图像 1,1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Inner Back Shield: 步骤 4 中的图像 1,1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: 步骤 5 中的图像 1,1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: 步骤 6 中的图像 1,1
  7. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: 步骤 7 中的图像 1,1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Speakers: 步骤 8 中的图像 1,1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: 步骤 9 中的图像 1,2 Fujitsu Lifebook Stylistic Q584 Speakers Replacement: 步骤 9 中的图像 2,2
    • Use the narrow plastic opening tool to pry the speakers from the casing.
  10. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: 步骤 10 中的图像 1,1
    • Unplug the speaker wires from the motherboard.
结论
Connor Stanton
于09/21/17注册
613 声望
创作了6篇指南
团队
1指南评论
Hello,
Thanks for this guide.
Is the ssd storage card replaceable on the q584.
I want to put a 256gb card internally.
Also, I notice a slot where the 4G /LTE modem goes.
Do you know the part number of that addition.
Thanks
Vince - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 31
总计 842
