跳转到主内容
Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement
你所需要的
  1. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Back Case: 步骤 1 中的图像 1,1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Inner Back Shield: 步骤 4 中的图像 1,1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 6 中的图像 1,1
  7. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Battery: 步骤 8 中的图像 1,1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 9 中的图像 1,1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 10 中的图像 1,1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 11 中的图像 1,1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Headphone Jack: 步骤 12 中的图像 1,1
    • Remove the two 0.2 mm screws with a PH00 Screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 13 中的图像 1,1
    • Remove the two 0.2 mm screws with a PH00 screwdriver
  14. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 14 中的图像 1,1
    • Now use an ESD-safe spudger to gently pry up the silver piece and flip it over. Be sure not to remove this piece completely!
  15. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 15 中的图像 1,2 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 15 中的图像 2,2
    • Use an ESD-safe spudger to gently push the yellow piece out from the white cradle.
  16. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 16 中的图像 1,2 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 步骤 16 中的图像 2,2
    • When removing the headphone jack, simply use your fingers to pull out the white and black piece altogether.
结论
另外一个人完成了本指南。
团队
IUPUI, Team S1-G1, Henning Spring 2019 IUPUI, Team S1-G1, Henning Spring 2019 的会员
IUPUI-HENNING-S19S1G1
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 593
