跳转到主内容
Fujitsu Lifebook Stylistic Q584 Back Case Replacement
你所需要的
  1. Fujitsu Lifebook Stylistic Q584 Back Case Replacement, Back Case: 步骤 1 中的图像 1,1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Back Case Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Back Case Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
结论
Spencer Bacon
于09/21/17注册
410 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 823
