简介
If the power port stops working you can use this guide to replace it. During this guide be careful as you are working on electronics as you remove the wires indicated in this guide to ensure no further damage to your device.
你所需要的
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
即将完成!
结论
