跳转到主内容
Fujitsu LifeBook U810 Wireless LAN card Replacement
你所需要的
  1. Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: 步骤 1 中的图像 1,3 Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: 步骤 1 中的图像 2,3 Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: 步骤 1 中的图像 3,3
    • Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
  2. Fujitsu LifeBook U810 Wireless LAN card Replacement: 步骤 2 中的图像 1,3 Fujitsu LifeBook U810 Wireless LAN card Replacement: 步骤 2 中的图像 2,3 Fujitsu LifeBook U810 Wireless LAN card Replacement: 步骤 2 中的图像 3,3
    • Remove the two 5mm screws with a Phillips #0 screwdriver.
    • Remove the wireless LAN card from the device.
  3. Fujitsu LifeBook U810 Wireless LAN card Replacement: 步骤 3 中的图像 1,2 Fujitsu LifeBook U810 Wireless LAN card Replacement: 步骤 3 中的图像 2,2
    • Detach the two antenna cables connected to the wireless LAN card by gently pulling them out of place.
结论
Anne Kutt
于10/22/18注册
197 声望
撰写一个指南
团队
UC Davis, Team S4-G7, Lore Fall 2018 UC Davis, Team S4-G7, Lore Fall 2018 的会员
UCD-LORE-F18S4G7
3 名成员
创作了4篇指南
一条评论
Is there a BIOS whitelist for this machine? I wanted to replace my wifi card due to OS incompatibility but I've seen conflicting reports.
Adam Birnbaum - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 20
总计 636
