当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
Lift the hinge cover enough to expose the ribbon cable.
The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
Lift the keyboard enough to expose the ribbon cable.
Remove the following screws, all labeled "3."
Two 8.63mm screws.
One 7.65mm screw.
One 5.74mm screw.
Remove the following screw, labeled "15."
One 17.81mm screw.
Lift the palm rest cover from the base of the laptop.
You may use spudger if needed, lift from the front corners as shown.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
