跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Fujitsu LifeBook N3510 Wireless Module Replacement
你所需要的
  1. Fujitsu LifeBook N3510 Wireless Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: 步骤 3 中的图像 1,3 Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: 步骤 3 中的图像 2,3 Fujitsu LifeBook N3510 Wireless Module Replacement, Hinge Cover: 步骤 3 中的图像 3,3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 4 中的图像 1,1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 5 中的图像 1,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 5 中的图像 2,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 6 中的图像 1,2 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 6 中的图像 2,2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 7 中的图像 1,2 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 7 中的图像 2,2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: 步骤 8 中的图像 1,3 Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: 步骤 8 中的图像 2,3 Fujitsu LifeBook N3510 Wireless Module Replacement, Keyboard: 步骤 8 中的图像 3,3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 9 中的图像 1,2 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 10 中的图像 1,2 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 10 中的图像 2,2
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Wireless Module Replacement, Metal Motherboard Cover: 步骤 11 中的图像 1,1
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 12 中的图像 1,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 12 中的图像 2,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 12 中的图像 3,3
    • Lift the cover with fingers and remove.
  13. Fujitsu LifeBook N3510 Wireless Module Replacement, Display: 步骤 13 中的图像 1,1
    • Remove labeled screws.
  14. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 14 中的图像 1,1
    • Remove the screws from the bottom of the hinge as shown in the image.
  15. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 15 中的图像 1,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 15 中的图像 2,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 15 中的图像 3,3
    • Use a spudger to detach and remove cables from the motherboard.
  16. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 16 中的图像 1,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 16 中的图像 2,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 16 中的图像 3,3
    • Unplug highlighted cables from the wireless module.
  17. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 17 中的图像 1,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 17 中的图像 2,3 Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 17 中的图像 3,3
    • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
  18. Fujitsu LifeBook N3510 Wireless Module Replacement, Top Palm Rest Cover: 步骤 18 中的图像 1,1
    • Remove the 4 labeled screws.
  19. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 19 中的图像 1,1
    • Remove screws from bottom of laptop as shown in the picture.
  20. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 20 中的图像 1,1
    • Lift the palm rest cover from the base of the laptop.
    • You may use spudger if needed, lift from the front corners as shown.
  21. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 21 中的图像 1,1
    • Great job! You have successfully removed the old palm rest cover.
  22. Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: 步骤 22 中的图像 1,3 Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: 步骤 22 中的图像 2,3 Fujitsu LifeBook N3510 Wireless Module Replacement, Wireless Module: 步骤 22 中的图像 3,3
    • Push securing clips outward, the wireless module will pop out.
    • Remove the wireless module.
  23. Fujitsu LifeBook N3510 Wireless Module Replacement: 步骤 23 中的图像 1,1
    • A picture of the removed wireless module is shown to the left.
结论
Neil Daniels
于01/17/11注册
1,411 声望
创作了11篇指南
团队
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G18
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 2,357
