当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate the two clips on the bottom of the computer that support the battery.
Using your fingers, push the clips inward and then upward.
Lift the battery out of the computer.
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Lay the computer flat on a stable surface with the monitor pointing away from you.
Use a spudger to partially lift the hinge cover.
The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
Lift the hinge cover enough to expose the ribbon cable.
Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
取消:我没有完成这个指南。
与8其他贡献者
于01/17/11注册
1,411 声望
创作了11篇指南
徽章: 12
+ 9更多徽章
CPSU-AMIDO-W11S5G18
3 名成员
创作了22篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 12
总计 3,412
