跳转到主内容
Fujitsu LifeBook N3510 Hinge Cover Replacement
你所需要的
  1. Fujitsu LifeBook N3510 Hinge Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: 步骤 3 中的图像 1,3 Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: 步骤 3 中的图像 2,3 Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: 步骤 3 中的图像 3,3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 4 中的图像 1,1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 5 中的图像 1,3 Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 5 中的图像 2,3 Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 6 中的图像 1,2 Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 6 中的图像 2,2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 7 中的图像 1,2 Fujitsu LifeBook N3510 Hinge Cover Replacement: 步骤 7 中的图像 2,2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
结论
Neil Daniels
于01/17/11注册
1,411 声望
创作了11篇指南
团队
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G18
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 3,418
