跳转到主内容
加入维修社区 - 创建账户
Fujitsu LifeBook N3510 Display Replacement
你所需要的
  1. Fujitsu LifeBook N3510 Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Display Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: 步骤 3 中的图像 1,3 Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: 步骤 3 中的图像 2,3 Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: 步骤 3 中的图像 3,3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Display Replacement: 步骤 4 中的图像 1,1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Display Replacement: 步骤 5 中的图像 1,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 5 中的图像 2,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Display Replacement: 步骤 6 中的图像 1,2 Fujitsu LifeBook N3510 Display Replacement: 步骤 6 中的图像 2,2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Display Replacement: 步骤 7 中的图像 1,2 Fujitsu LifeBook N3510 Display Replacement: 步骤 7 中的图像 2,2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Display Replacement, Keyboard: 步骤 8 中的图像 1,3 Fujitsu LifeBook N3510 Display Replacement, Keyboard: 步骤 8 中的图像 2,3 Fujitsu LifeBook N3510 Display Replacement, Keyboard: 步骤 8 中的图像 3,3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Display Replacement: 步骤 9 中的图像 1,2 Fujitsu LifeBook N3510 Display Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Display Replacement: 步骤 10 中的图像 1,2 Fujitsu LifeBook N3510 Display Replacement: 步骤 10 中的图像 2,2
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Display Replacement, Metal Motherboard Cover: 步骤 11 中的图像 1,1
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Display Replacement: 步骤 12 中的图像 1,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 12 中的图像 2,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 12 中的图像 3,3
    • Lift the cover with fingers and remove.
  13. Fujitsu LifeBook N3510 Display Replacement, Display: 步骤 13 中的图像 1,1
    • Remove labeled screws.
  14. Fujitsu LifeBook N3510 Display Replacement: 步骤 14 中的图像 1,1
    • Remove the screws from the bottom of the hinge as shown in the image.
  15. Fujitsu LifeBook N3510 Display Replacement: 步骤 15 中的图像 1,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 15 中的图像 2,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 15 中的图像 3,3
    • Use a spudger to detach and remove cables from the motherboard.
  16. Fujitsu LifeBook N3510 Display Replacement: 步骤 16 中的图像 1,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 16 中的图像 2,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 16 中的图像 3,3
    • Unplug highlighted cables from the wireless module.
  17. Fujitsu LifeBook N3510 Display Replacement: 步骤 17 中的图像 1,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 17 中的图像 2,3 Fujitsu LifeBook N3510 Display Replacement: 步骤 17 中的图像 3,3
    • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
结论
2等其他人完成本指南。
Neil Daniels
于01/17/11注册
1,411 声望
创作了11篇指南
团队
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G18
3 名成员
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 42
总计 4,794
