简介
In this guide, you will learn how to safely replace the hard drive of a Fujitsu LIFEBOOK P7010D laptop.
Typically, laptop hard drives should be replaced every 3-5 years. If you keep track of your hard drive’s age, you can preemptively replace it before it fails. Hard drive failure can lead to slow functioning, data corruption, and overheating.
你所需要的
Push the tab down as far as possible using your finger or opening tool to unlock the disc drive.
While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
On the bottom of the laptop, find the two bottom-plate screw holes near the disc drive. Parallel to them is a 2.4mm screw (second photo).
After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew it.
3等其他人完成本指南。
1指南评论
hai sir..please help me..how to replacement hdd lifebook PH770/5AN ? can you answer to my email antogantengnian@gmail.com..thanks a lot
anto adhitya - 回复 分享
