跳转到主内容
Fujitsu LIFEBOOK P7010D Audio Speakers Replacement
你所需要的
  1. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop upside down on a table.
  2. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 2 中的图像 1,1
    • Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Using your fingers, press both tabs down at once until they are fully depressed.
  3. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 3 中的图像 1,1
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement, Keyboard: 步骤 4 中的图像 1,2 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Unscrew three 2.4mm and one 5.7mm screws using a Phillips # 0.
    • Unscrew three 1.9mm screws in the battery compartment still using a Phillips # 0
  5. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 5 中的图像 1,3 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 5 中的图像 2,3 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 5 中的图像 3,3
    • Mind the wire connections on the bottom right side of the monitor. They are still connected between the monitor and computer.
    • Raise the monitor as you normally would until it pops out by itself. Rotate the left side up and to the right to unhook hinges that may catch on the computer.
    • Lay the monitor flat next to the computer.
  6. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 6 中的图像 1,2 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Using a smaller spudger (like a PX3688), pivot the sound case out above the "F2" and "Insert" buttons.
    • Lift the case out and set it aside.
    • For the proceeding steps, put on your anti-static wrist strap and attach the metal clip to something metal and grounded in order to protect the delicate circuitry inside the computer.
  7. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 7 中的图像 1,3 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 7 中的图像 2,3 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 7 中的图像 3,3
    • Using the same spudger, pry the top of the keyboard up above the "F2" key.
    • Turn the computer so that the bottom is facing you.
    • The keyboard is connected to a black plastic strip, slowly pull the keyboard and place it to the side.
  8. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 8 中的图像 1,2 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 8 中的图像 2,2
    • Disconnect the keyboard by gently pulling on the hard plastic square straight up from the white connector.
  9. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement, Audio Speakers: 步骤 9 中的图像 1,3 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement, Audio Speakers: 步骤 9 中的图像 2,3 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement, Audio Speakers: 步骤 9 中的图像 3,3
    • Remove four 2.4mm screws using the Phillips #0 screwdriver from each side of the audio speakers.
    • Note that the speaker with the white and black wires are on the left and the red and black wires are on the right.
    • Place the speakers to the side of the computer.
  10. Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 10 中的图像 1,3 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 10 中的图像 2,3 Fujitsu LIFEBOOK P7010D Audio Speakers Replacement: 步骤 10 中的图像 3,3
    • Use your fingers or a spudger to remove the white connector from its port.
结论
另外一个人完成了本指南。
Nicholas Ross
于01/20/12注册
186 声望
创作了7篇指南
团队
Cal Poly, Team 10-31, Amido Winter 2012 Cal Poly, Team 10-31, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G31
5 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 29
总计 3,612
