跳转到主内容
Fujifilm XP20 Rear Case Replacement
你所需要的
  1. Fujifilm XP20 Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,3 Fujifilm XP20 Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,3 Fujifilm XP20 Rear Case Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Using a 1.5mm Hex Screwdriver, remove the two 3.0 mm hex screws on the front of the camera.
    • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws on the bottom of the front face.
  2. Fujifilm XP20 Rear Case Replacement: 步骤 2 中的图像 1,3 Fujifilm XP20 Rear Case Replacement: 步骤 2 中的图像 2,3 Fujifilm XP20 Rear Case Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screws on the bottom of the camera closer to the back.
    • Using a Phillips #00 screwdriver remove the two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. Fujifilm XP20 Rear Case Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. Fujifilm XP20 Rear Case Replacement: 步骤 4 中的图像 1,3 Fujifilm XP20 Rear Case Replacement: 步骤 4 中的图像 2,3 Fujifilm XP20 Rear Case Replacement: 步骤 4 中的图像 3,3
    • Using a 1.5mm Hex screwdriver, remove the 3.0 mm hex screw on top edge of silver panel.
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. Fujifilm XP20 Rear Case Replacement: 步骤 5 中的图像 1,3 Fujifilm XP20 Rear Case Replacement: 步骤 5 中的图像 2,3 Fujifilm XP20 Rear Case Replacement: 步骤 5 中的图像 3,3
    • Unlatch the four clasps located on each side of the camera by hand.
    • The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm XP20 Battery Replacement for instructions.
  6. Fujifilm XP20 Rear Case Replacement: 步骤 6 中的图像 1,3 Fujifilm XP20 Rear Case Replacement: 步骤 6 中的图像 2,3 Fujifilm XP20 Rear Case Replacement: 步骤 6 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
结论
Stephen Harden
于10/08/16注册
243 声望
创作了2篇指南
团队
IUPUI, Team 1-1, Wilson Fall 2016 IUPUI, Team 1-1, Wilson Fall 2016 的会员
IUPUI-WILSON-F16S1G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 10
总计 591
