简介
This guide introduces how to replace the motherboard in the Fujifilm X30 camera. Reasons for replacing the motherboard are outlined in the troubleshooting guide. Removing the motherboard requires soldering. Learn more about soldering here.
你所需要的
Turn the camera upside down.
Place your thumb on the switch, and slide it towards the center of the camera.
Begin by removing the outside screws using a Phillips #000 Screwdriver:
Remove the three 3.6 mm silver screws located on the bottom of the camera.
Remove all four of the 4.7 mm screws from the sides of the camera.
Remove all screws listed below using a Phillips #000 screwdriver:
Remove the two 3.4 mm screws at the bottom of the silver plate.
Hold back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
Peel back the copper plate.
Tilt up the motherboard to locate the black, grey, and red wires.
Desolder these wires in order to completely remove the motherboard.
If you want to remove baterry holder case you'll have to unscrew it from the body through the hole you see on the plate. There's another hole under the black tape. Use it to reach another screw. You can then get the case out and work easily for soldering.
2等其他人完成本指南。
2条评论
On step 11 becareful not to detach flex surface from aluminium plate. You could end up braking CCD contacts as I did.
