跳转到主内容
Fujifilm X30 Lens Replacement
你所需要的
  1. Fujifilm X30 Lens Replacement, Battery: 步骤 1 中的图像 1,2 Fujifilm X30 Lens Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera upside down.
    • Place your thumb on the switch, and slide it towards the center of the camera.
    • The compartment will pop open.
  2. Fujifilm X30 Lens Replacement: 步骤 2 中的图像 1,1
    • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
  3. Fujifilm X30 Lens Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out.
  4. Fujifilm X30 Lens Replacement, Lens: 步骤 4 中的图像 1,3 Fujifilm X30 Lens Replacement, Lens: 步骤 4 中的图像 2,3 Fujifilm X30 Lens Replacement, Lens: 步骤 4 中的图像 3,3
    • Begin by removing the outside screws using a Phillips #000 Screwdriver:
    • Remove the three 3.6 mm silver screws located on the bottom of the camera.
    • Remove all four of the 4.7 mm screws from the sides of the camera.
  5. Fujifilm X30 Lens Replacement: 步骤 5 中的图像 1,2 Fujifilm X30 Lens Replacement: 步骤 5 中的图像 2,2
    • Remove all screws listed below using a Phillips #000 Screwdriver:
    • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
    • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
  6. Fujifilm X30 Lens Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the bottom piece of the camera.
  7. Fujifilm X30 Lens Replacement: 步骤 7 中的图像 1,1
    • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
    • Gently pull off the back of the camera from the left side so that it is partially open.
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
    • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
  8. Fujifilm X30 Lens Replacement: 步骤 8 中的图像 1,3 Fujifilm X30 Lens Replacement: 步骤 8 中的图像 2,3 Fujifilm X30 Lens Replacement: 步骤 8 中的图像 3,3
    • For all five indicated orange strips:
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
  9. Fujifilm X30 Lens Replacement: 步骤 9 中的图像 1,1
    • For the final orange strip located behind the top strip:
  10. Fujifilm X30 Lens Replacement: 步骤 10 中的图像 1,3 Fujifilm X30 Lens Replacement: 步骤 10 中的图像 2,3 Fujifilm X30 Lens Replacement: 步骤 10 中的图像 3,3
    • Remove the two 3.4 mm screws at the bottom of the silver plate.
    • Peel back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
    • Peel back the copper plate.
  11. Fujifilm X30 Lens Replacement: 步骤 11 中的图像 1,1
    • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 Screwdriver.
    • Lift the motherboard so it is out of your way to remove the lens.
    • You do not need to desolder the motherboard to reach the lens.
  12. Fujifilm X30 Lens Replacement: 步骤 12 中的图像 1,1
    • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 Screwdriver.
  13. Fujifilm X30 Lens Replacement: 步骤 13 中的图像 1,2 Fujifilm X30 Lens Replacement: 步骤 13 中的图像 2,2
    • Pull the lens down so it can clear the silver tab.
    • Then push the lens with your index fingers from the front of the camera until it is removed.
结论
4等其他人完成本指南。
Haley Moss
于01/11/16注册
354 声望
撰写一个指南
团队
Cal Poly, Team 70-3, Forte Winter 2016 Cal Poly, Team 70-3, Forte Winter 2016 的会员
CPSU-FORTE-W16S70G3
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 59
总计 4,528
