跳转到主内容
Fujifilm X100T Lens Replacement
你所需要的
  1. Fujifilm X100T Lens Replacement, Battery: 步骤 1 中的图像 1,3 Fujifilm X100T Lens Replacement, Battery: 步骤 1 中的图像 2,3 Fujifilm X100T Lens Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the small black tab on the bottom of the camera to the left to unlock the battery cover.
    I would Like to find out the price for the mother board s4250wm fine pix for the fujifilm
    lucasroger75 - 回复
  2. Fujifilm X100T Lens Replacement: 步骤 2 中的图像 1,3 Fujifilm X100T Lens Replacement: 步骤 2 中的图像 2,3 Fujifilm X100T Lens Replacement: 步骤 2 中的图像 3,3
    • Push the orange tab up to release the battery.
    • Slide the battery out of the camera.
    • Invert the camera to slide out the battery more easily.
  3. Fujifilm X100T Lens Replacement, Lens: 步骤 3 中的图像 1,2 Fujifilm X100T Lens Replacement, Lens: 步骤 3 中的图像 2,2
    • Beginning in one of the corners, use a spudger to pry the leather casing off of the camera.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Fujifilm X100T Lens Replacement: 步骤 4 中的图像 1,1
    • Carefully and slowly peel the leatherette skin off of the camera by hand.
  5. Fujifilm X100T Lens Replacement: 步骤 5 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 5 中的图像 2,2
    • Locate the six 4.0 mm screws on the bottom of the camera.
    • Use a JIS#000 driver to remove these screws.
    The two srews on the left can be left in place as these just keep the tripod mount fixed to the bottom plate. (see pictures at step 7)
    Frank - 回复
    Exactly as Frank said.
    Please update the repair guide for those who don’t read all the comments.
    Ondrej Pok -
  6. Fujifilm X100T Lens Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Mako Driver Kit - 64 Precision Bits
    $39.95
    购买
    • This is a camera produced by a Japanese camera manufacturer. The Japanese camera industry loves using JIS (Japanese Industrial Standard) screws.
    • Don't be tempted by your Phillips screw driver collection. Although PH#00 will interchange with JIS#00, it is not a perfect fit. Using Phillips will cause more wear on the head of the JIS screws and cause the screws to prematurely strip.
    • Have both JIS#00 and JIS#000 screw drivers available for this teardown. Luckily, both bits are included in the ifixit 64bit kit.
  7. Fujifilm X100T Lens Replacement: 步骤 7 中的图像 1,1
    • Remove the bottom plate and the tripod mount by lifting them using your hands.
    • The tripod mount is keyed and fits into a series of pegs on the back side of the bottom plate.
    Actually it’s not that simple. I was stuck here until I realised that two more screws need to be loosened. See step 10 and loosen the bottom one behind the port cover and step 12 loosen the bottom right one. This is why you need to peel the leatherette skin in step 4.
    Frank - 回复
  8. Fujifilm X100T Lens Replacement: 步骤 8 中的图像 1,3 Fujifilm X100T Lens Replacement: 步骤 8 中的图像 2,3 Fujifilm X100T Lens Replacement: 步骤 8 中的图像 3,3
    • Get your picks ready!
    • To get any deeper into this camera, the right-hand port cover assembly must be removed first. Once this is removed, you will have access to the screws that secure the other components.
    • There's a tiny hole toward the bottom right of the battery compartment. Using the pick tool, press into that hole.
    • A plastic rod will release. That plastic rod is the axis the hinge rotates about.
    I can not release the plastic rod..
    Zusmitha Jane Corpuz - 回复
    I can not even press the hole. Can someone help me
    Try rotating the hinge by moving the flap back and forth. Then try pushing out the rod again. Good luck.
    Anthony Kouttron -
  9. Fujifilm X100T Lens Replacement: 步骤 9 中的图像 1,3 Fujifilm X100T Lens Replacement: 步骤 9 中的图像 2,3 Fujifilm X100T Lens Replacement: 步骤 9 中的图像 3,3
    • Fuji! What did we tell you about hiding screws behind closed doors! That's pretty under the table Fuji. Don't do it again. Promise?
    • The devil's in the details with this camera. Slide the port cover off the hinge rod.
    • Using a pair of pliers, pull the rod out of the top plate of the camera. Now you'll finally have access to all the screws that need to be removed.
  10. Fujifilm X100T Lens Replacement: 步骤 10 中的图像 1,3 Fujifilm X100T Lens Replacement: 步骤 10 中的图像 2,3 Fujifilm X100T Lens Replacement: 步骤 10 中的图像 3,3
    • Remove the three 5.0 mm screws by the micro-USB, micro-HDMI and remote ports.
    • Remove the screw hidden behind the port cover hinge.
    • The port cover assembly should come off with ease. If it is stuck, try prying with plastic shims.
    There is a fourth screw under the flap part that must be removed before the plastic facing will come off the frame.
    cyrways - 回复
  11. Fujifilm X100T Lens Replacement: 步骤 11 中的图像 1,1
    • Remove the two 6.0 mm screws beneath the port cover assembly.
    the bottom one, where the screwdriver is in the picture is already removed in the previous step. only one screw left at this stage.
    savooi - 回复
  12. Fujifilm X100T Lens Replacement: 步骤 12 中的图像 1,1
    • Remove the four 5.0 mm screws on the side of the camera that is opposite to the battery.
  13. Fujifilm X100T Lens Replacement: 步骤 13 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 13 中的图像 2,2
    • Remove the two 2.5 mm screws on the bottom face of the camera.
    • The rear LCD & button assembly should now pivot up and to the right, exposing the LCD & button ribbon cables.
  14. Fujifilm X100T Lens Replacement: 步骤 14 中的图像 1,1
    • Once the electronics are exposed, it is highly recommended that you remain ESD safe. ESD can fry your precious electronics, and pass thousands of volts through components only rated for a few V DC. ESD can sure ruin your day if you are not careful.
    • Use an ESD mat and wrist strap, and make sure you are grounded for the remaining of the teardown. Make sure your ESD mat is connected to the ground of a nearby outlet, and make sure your house actually has a ground. Consult an electrician if you are unsure.
  15. Fujifilm X100T Lens Replacement: 步骤 15 中的图像 1,3 Fujifilm X100T Lens Replacement: 步骤 15 中的图像 2,3 Fujifilm X100T Lens Replacement: 步骤 15 中的图像 3,3
    • Remove the orange ribbon cable by opening up the ZIF connector with a plastic prying tool or toothpick.
    • This separates the LCD from the main board.
    In my camera an additional black tape is securing the ZIF connector and the orange ribbon cable. After pulling it off I could flip the ZIF connector open from the side of the ribbon cable. A magnifying glass was very helpful.
    Frank - 回复
  16. Fujifilm X100T Lens Replacement: 步骤 16 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 16 中的图像 2,2
    • Remove the white/blue ribbon cable from the motherboard by gently pulling with your hands.
    • The LCD and button assembly should now be fully detached.
  17. Fujifilm X100T Lens Replacement: 步骤 17 中的图像 1,1
    • Remove the 2.5 mm screw in the center, above the removed LCD screen.
    • Remove the two 4.0 mm screws on the right.
  18. Fujifilm X100T Lens Replacement: 步骤 18 中的图像 1,1
    • Remove the two 4.5 mm screws on the side of the camera opposite of the battery.
  19. Fujifilm X100T Lens Replacement: 步骤 19 中的图像 1,1
    • Peel off the copper tape connecting the frame to the camera.
    • This allows for ground continuity and partial heat dissipation for inner components.
  20. Fujifilm X100T Lens Replacement: 步骤 20 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 20 中的图像 2,2
    • Remove the adhesive tape holding the speaker.
    • The speaker is held into place by double sided tape. Pull it off the steel frame and move it toward the bottom of the camera
    • This protects the speaker wires from getting clipped by the removal of the steel frame.
  21. Fujifilm X100T Lens Replacement: 步骤 21 中的图像 1,1
    • Remove these two ribbon cables so they don't get cut or damaged when removing the entire steel frame.
    • Use a pair of tweezers or small, blunt object to remove these ribbon cables. They are in a tight location so have patience and be gentle
  22. Fujifilm X100T Lens Replacement: 步骤 22 中的图像 1,1
    • Fold back the steel frame by lifting it off and gently pulling it to the side using your hand.
    • Be careful not to detach the frame from the camera.
    • Remove the three 4.2 mm screws on the green chip.
  23. Fujifilm X100T Lens Replacement: 步骤 23 中的图像 1,3 Fujifilm X100T Lens Replacement: 步骤 23 中的图像 2,3 Fujifilm X100T Lens Replacement: 步骤 23 中的图像 3,3
    • Locate the orange ribbon cable on the side of the camera that has the battery slot.
    • Remove the ribbon cable from the ZIF socket using a plastic opening tool.
    • Remove the ribbon by lifting it off with your hands.
  24. Fujifilm X100T Lens Replacement: 步骤 24 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 24 中的图像 2,2
    • Remove the rubber eyepiece guard by lifting it off with your hands.
    • If the rubber eyepiece is being stubborn, an old giftcard won't mind :D
    • Remember, your Mohs hardness scale! This camera uses metalized plastic extensively.
    Can you remove this part without doing the first 23 steps?
    Cornelius Ryan Paglomutan - 回复
  25. Fujifilm X100T Lens Replacement: 步骤 25 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 25 中的图像 2,2
    • Remove the two 4.0 mm screws from the front of the camera. These are most likely T1 torx screws.
    • I can't stress enough how tiny these screws are. Pencil point sized.
    • Fuji, screws are a thing of beauty. Why are you trying to hide them?
    • The closest bit in the ifixit kit is the star shaped #2 screw head.
    • Using the wrong bit will strip the Torx screw head, so keep that in mind.
  26. Fujifilm X100T Lens Replacement: 步骤 26 中的图像 1,1
    • Remove the top frame by lifting it off and pulling it towards the backside of the camera.
  27. Fujifilm X100T Lens Replacement: 步骤 27 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 27 中的图像 2,2
    • Use a plastic opening tool to detach the two ribbon cables from the top frame.
  28. Fujifilm X100T Lens Replacement: 步骤 28 中的图像 1,1
    • Locate the adhesive connecting the black and red wires above the green board.
    • Remove the adhesive by gently pulling it off with your hand.
    • Remove the copper tape that grounds the sensor heatsink to the sensor PCB.
  29. Fujifilm X100T Lens Replacement: 步骤 29 中的图像 1,1
    • Use a plastic opening tool to pry off the ribbon located next to the top-right of the green sensor board.
  30. Fujifilm X100T Lens Replacement: 步骤 30 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 30 中的图像 2,2
    • Use a plastic opening tool and metal tweezers to lift up the ribbon located next to the center-right section of the green board.
    • Going any further into the camera is guaranteed to destroy the calibration of the sensor box in the camera. The plane of the sensor is calibrated to the plane of the lens elements or lens mount. Adjusting the tension on any sensor box mount screw makes the sensor and elements out of orthogonal alignment.
    • Remove the CMOS sensor aluminum heatsink by lifting it up with your hands. The sensor, PCB and heatsink are integrated into one unit.
    • With the sensor assembly removed, you should now be able to be able to see the silver lens cover beneath.
    Twofold question here:
    * It's not easy to tell from the photos, but what is preventing removal of the motherboard without removing the image sensor?
    * With some cameras it's possible to mark the positions of the sensor mounting screws, tighten them all the way down to determine their absolute position, then remove them--yielding some sort of confidence in the ability to reinstall them to their original position. Is that feasible here?
    Great teardown guide, thanks!
    Jeremy Rosenberger - 回复
  31. Fujifilm X100T Lens Replacement: 步骤 31 中的图像 1,1
    • You should be wearing nitrile gloves when working with lens assemblies. Oils from fingerprints leave marks on the lens elements and cause major headaches during reassembly.
    • If you left fingerprints on a lens, you want to identify if it is plastic or glass and clean with the appropriate cleaning agent. If it is glass, use reagent grade Isopropyl alcohol + lens wipes. If plastic use a plastic friendly alcohol or cleaner. Some clear plastics become opaque with Isopropyl alcohol.
    • Remove the four 3.2 mm screws on the silver lens cover.
  32. Fujifilm X100T Lens Replacement: 步骤 32 中的图像 1,1
    • Use a plastic opening tool to lift up the silver lens cover.
    • You should now be able to see the black lens cover underneath.
  33. Fujifilm X100T Lens Replacement: 步骤 33 中的图像 1,1
    • Remove the three 3.5 mm screws on the black lens cover.
  34. Fujifilm X100T Lens Replacement: 步骤 34 中的图像 1,1
    • Lift up the black lens cover with your hands.
    • You should now be able to see the spring-loaded lens.
  35. Fujifilm X100T Lens Replacement: 步骤 35 中的图像 1,2 Fujifilm X100T Lens Replacement: 步骤 35 中的图像 2,2
    • Remove the three 3.5 mm screws on the spring-loaded cover.
  36. Fujifilm X100T Lens Replacement: 步骤 36 中的图像 1,1
    • Remove the spring and the lens by gently lifting both the components upwards.
    May i know where is the capacitor connected?
    I accidentally dettached the two wires..
    Can someone help me? Ty
结论
To reassemble your camera's lens, follow these instructions in reverse order.
4等其他人完成本指南。
Thang Bui
于01/12/16注册
507 声望
撰写一个指南
团队
Cal Poly, Team 70-1, Forte Winter 2016 Cal Poly, Team 70-1, Forte Winter 2016 的会员
CPSU-FORTE-W16S70G1
4 名成员
创作了5篇指南
3条评论
can you tel us how to put it back together.
Cameron Blakey - 回复
Is it possible to open the lens unit from front? Without disassembling the body?
arfft - 回复
I no longer have the Fuji x100T, but it may be possible to disassemble the lens from the front. Many modern cameras have a glued-on beauty ring / lens nameplate ring on the front of the lens. The ring I am specifically referring to is the “Fujinon Aspherical Lens Super EBC f23mm 1:2.” Nameplate rings are traditionally used to hide screws or a circular threaded ring which holds the lens together. Here is an example, specifically at 9:46min mark http://www.youtube.com/watch?v=yRPwEsAYz...
I would suggest watching more of mikeno62’s lens repair videos to get familiar with lens disassembly. I don’t have a service manual for this camera, but there may be screws hidden behind the nameplate ring.
Make sure to take your time with the lens disassembly. Be careful of the hardness of the tool you use. Plastic (mohs hardness of 2) wont scratch glass (mohs hardness of 5.5) and neither will rubber. Make sure to document the disassembly so you don’t reassemble the lens wrong. Work on a large empty table, you’ll need it! Good luck!
Anthony Kouttron -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 32
总计 7,254
