跳转到主内容
加入维修社区 - 创建账户
Fujifilm X-T10 Main PCB fuse locations Replacement
浏览量: 691
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
146
All Time:
691
评论: 0
Go to guide comments
已完成: 0
暂时还没有人将本指南标记为“已完成”。你会是第一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 没有估计
难度: 中等
社区贡献指南
我们社区的一个非常棒的成员制作了本指南。它不是由 iFixit 工作人员创建的。
If camera doesn't switch on and switch is not faulty it could be a blown fuse.
You need to remove tons of flex cable and desolder many wires before you can take the board out.
There is a main fuse marked T and another 2 fuses marked O on the back.
    1. Fujifilm X-T10 Main PCB fuse locations Replacement, Main PCB fuse locations: 步骤 1 中的图像 1,2 Fujifilm X-T10 Main PCB fuse locations Replacement, Main PCB fuse locations: 步骤 1 中的图像 2,2
      • You need to remove tons of flex cable and desolder many wires before you can take the board out.
      • There is a main fuse marked T on front and another 2 fuses marked O on the back.
      • Check with multimeter for continuity all fuses.
      询问修复机器人
      添加评论
      • make sure you close all the latch on the back of the PCB for the connectors. If one snap, you are in big trouble.
      • put solder on the pads first. However, make sure it is kind of flat so that you can place the fuse on it without sliding to the side.
      • put alcohol around the area. The tension of the alcohol keep the fuse in place. That is the key.
      • place the fuse on the pad and align properly. Use heat gun on low speed or work station to heat up the fuse and solders. cover the rest of the area with metal plates if you can. You don't want any other components to move.
      • when you think it is done, stop the heat and use a tweezer to try lifting the fuse. If it moves, they put it back properly and continue. Repeat the process until the whole PCB is lifted instead of the fuse when you lift it. The O fuse is the hardest one of the fuse to replace. For people who never solder before, you don't need to try.
      • The original fuse is glued on the PCB, so you need to use some force to remove it. Alternatively just solder the old fuse on top of old one. O is 2.5A fuse and the size is 0603. T is 0.5A 0603, Fast-Acting SMF
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Oto
于01/11/26注册
157 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 32
过去 30 天: 146
All Time: 691
