跳转到主内容
Fujifilm Instax Minion Lens Bellow Replacement
你所需要的
  1. Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: 步骤 1 中的图像 1,3 Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: 步骤 1 中的图像 2,3 Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: 步骤 1 中的图像 3,3
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Lens Bellow Replacement: 步骤 2 中的图像 1,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 2 中的图像 2,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Lens Bellow Replacement: 步骤 3 中的图像 1,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 3 中的图像 2,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 3 中的图像 3,3
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Lens Bellow Replacement: 步骤 4 中的图像 1,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 4 中的图像 2,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 4 中的图像 3,3
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Lens Bellow Replacement: 步骤 5 中的图像 1,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 5 中的图像 2,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Lens Bellow Replacement: 步骤 6 中的图像 1,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 6 中的图像 2,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Lens Bellow Replacement, Lens Bellow: 步骤 7 中的图像 1,2 Fujifilm Instax Minion Lens Bellow Replacement, Lens Bellow: 步骤 7 中的图像 2,2
    • Once the shell is off, remove the two 4.5 mm screws from the circuit board using a Phillips #00 screwdriver.
  8. Fujifilm Instax Minion Lens Bellow Replacement: 步骤 8 中的图像 1,1
    • Once the circuit board is off and to the side, remove the four 4.5 mm screws that are around the front lens case using a Phillips #00 screwdriver.
  9. Fujifilm Instax Minion Lens Bellow Replacement: 步骤 9 中的图像 1,2 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 9 中的图像 2,2
    • Turn the camera onto its back and remove the four 4.5 mm screws attaching the lens bellow to the case using a Phillips #00 screwdriver.
    • The lens must be extended in order to have access to the screws.
    • Remove the rectangular screw casing from the back of the camera.
  10. Fujifilm Instax Minion Lens Bellow Replacement: 步骤 10 中的图像 1,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 10 中的图像 2,3 Fujifilm Instax Minion Lens Bellow Replacement: 步骤 10 中的图像 3,3
    • Flip the camera over to its front side again and remove the lens casing by lifting it up and off the camera.
    • Finally, remove the lens bellow by lifting it up and off the camera.
结论
Jonnah Lee
于04/18/18注册
473 声望
创作了3篇指南
团队
Cal Poly, Team S18-G6, Livingston Spring 2018 Cal Poly, Team S18-G6, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G6
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 555
