跳转到主内容
Fujifilm Instax Minion Capacitor Replacement
你所需要的
  1. Fujifilm Instax Minion Capacitor Replacement, Camera Shell: 步骤 1 中的图像 1,3 Fujifilm Instax Minion Capacitor Replacement, Camera Shell: 步骤 1 中的图像 2,3 Fujifilm Instax Minion Capacitor Replacement, Camera Shell: 步骤 1 中的图像 3,3
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Capacitor Replacement: 步骤 2 中的图像 1,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 2 中的图像 2,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Capacitor Replacement: 步骤 3 中的图像 1,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 3 中的图像 2,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 3 中的图像 3,3
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Capacitor Replacement: 步骤 4 中的图像 1,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 4 中的图像 2,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 4 中的图像 3,3
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Capacitor Replacement: 步骤 5 中的图像 1,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 5 中的图像 2,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Capacitor Replacement: 步骤 6 中的图像 1,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 6 中的图像 2,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Capacitor Replacement, Capacitor: 步骤 7 中的图像 1,3 Fujifilm Instax Minion Capacitor Replacement, Capacitor: 步骤 7 中的图像 2,3 Fujifilm Instax Minion Capacitor Replacement, Capacitor: 步骤 7 中的图像 3,3
    • Remove the four 4.5 mm screws inside the battery holder with a long #00 Phillips screwdriver.
  8. Fujifilm Instax Minion Capacitor Replacement: 步骤 8 中的图像 1,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 8 中的图像 2,3 Fujifilm Instax Minion Capacitor Replacement: 步骤 8 中的图像 3,3
    • Gently pull on the battery holder to remove it from the case, exposing the capacitor.
    • Pull up on the backside of the capacitor to remove it from the battery holder.
    • The capacitor will have a small amount of adhesive holding it onto the battery holder. Keep this intact, but don't worry if it is damaged.
    • Be careful not to touch the wire leads on the front of the capacitor, as you could get shocked.
  9. Fujifilm Instax Minion Capacitor Replacement: 步骤 9 中的图像 1,2 Fujifilm Instax Minion Capacitor Replacement: 步骤 9 中的图像 2,2
    • Desolder the ends of the wires from the leads of the capacitor to remove it.
    • Take note of the connections between the wires and leads for reassembly. The brown wire connects to side with white line and the white wire connects to the other side.
    • Be careful not to touch both leads of the capacitor with your soldering iron. This will bridge the connection and could create a spark.
结论
Jeffery
于03/28/15注册
220 声望
创作了2篇指南
团队
Cal Poly, Team S18-G6, Livingston Spring 2018 Cal Poly, Team S18-G6, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G6
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 669
