本指南有最近更改,您可查看未经巡查的最新版本。
简介
The camera shell is the plastic casing that makes up the outside of the Fujifilm Instax Mini 8; which is meant to hide wires, protect the film, and hold the main components of this camera together in a compact manner. A damaged shell will compromise the integrity of the device and may cause other parts of the camera to malfunction.
你所需要的
Start off by looking at your camera and rotating it to locate all the screws. There should be eight screws in all.
Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
12等其他人完成本指南。
18条评论
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
but where near the exit? i cannot find it
It's at the top of the camera where you get picture.
xxx -
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - 回复
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
